Results 1 to 10 of 11
Thread: help required fitting cd70 sat nav
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default help required fitting cd70 sat nav
    hi all ive got a 2006 vectra sri and have brought a cd70 and colour screen wot else would i need to get the sat nav up and running in my car i know i will need a aftermarket gps aireal but which sort ? also any extra wires needed and will all the rest work ok like mpg range and so on.
    thanks in advance.
    dean
    gwent
    What have you got altogether is it just the screen and head unit if so I beleave you need a new ribbon lead and gps lead someone else will tell you if you need anything else
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    What radio have you currently got? If it's a CD30 then I think you need to change the plug that's on the back of your screen Which is a 16pin to a 32pin. Get a Fraka GPS antena of ebay for about £10. I but the CD70 nav in mine which was all just plug and play as I had a CDC40 with a GID screen which has the same connection as the CID screen.
    Have a look at this How2 http://www.vectra-c.com/forum/showthread.php?t=70769
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    thanks for responce ive currently got a cd30 in my facelift vectra i have a gps antenna but dont have a cable to go from cd70 to colour screen.
    i have also looked at other thread about changing plugs is that for full canbus aswell.
    Nov 2009
    Belfast
    I would say so. You BID screen has a 16pin plug(I think) while the CID has 32. You would not need the BC stalk for your facelift as the steering wheel scrolls control your BC functions.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    anyone else know for defo without taking my car to bits ?
    milton keynes
    All should be plug and play , but you need the loom between cid and headunit. You wont need a 32 pin plug , as you already have one being a full canbus car. Just need to add the gps antenae
    Nov 2009
    Belfast
    Ah I wasn't sure about the 32pin plug. The cable you need is a RGB cable. Your nav will work without it displaying directional arrows and voice control but no map.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    niall83 and kman cheers just need to source a rgb cable.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    just need to find a RGB cable now.
  1. Urgent help required! Fitting electric seats
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2013, 23:46
  2. CD70 AUX in required
    By Vectralicker in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2011, 11:28
  3. CD70 help & info required
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2010, 15:41
  4. Springs - fitting? help required!
    By Vauxhall Thru & Thru in forum Handling & Braking
    Last Post: 28th June 2008, 10:36
  5. Urgent help required - H.I.D fitting problem
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2007, 10:29
fitting a sat nav to 2007 vectra 1.9 cdti
