Thread: drivers door lock
    Sep 2011
    wales
    Default drivers door lock
    Hi Guys,
    the drivers door on my vec C elite 2007 does not open from the inside.
    opens fine from the outside central locking working fine ect. does anyone know if i need to change the whole lock or just the solenoid?
    is it a dificult job?
    Eddy
    Regular Member Innes's Avatar
    Plymouth
    There is a how2 on how to change the lock. I did mine and it was diddly.
    Does the door pin push down ok or is there resistance?
    Sep 2011
    wales
    nope door pin pushes down fine
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    your door pull rod may have fallen off u will have to take the door card off and have a look
    Sep 2011
    wales
    the cable is connected to the handle in the door card need to get the lock off to have a look at the other end
  1. Drivers Door Lock Switch Help
    By UltraVec in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 16:31
  2. Drivers Door Lock not working
    By Rupster_69 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 16:07
  3. De-lock Drivers Door...
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 14:43
  4. Drivers Door lock problem
    By r3m0dul8 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 10:43
