Thread: Lowering Springs Apex -Eibachs require Heavy Duty Rods?
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Lowering Springs Apex -Eibachs require Heavy Duty Rods?
    Hi All,
    My Vectra C Elite Pre-Facelift. I require new inner tie rod ends and track ends for front. I have been told its better to get the HEAVY DUTY ones fitted as the normal ones will have premature wear. Is this right? Should I also change the Rear as well? Where Can I buy the Heavy duty rods?
    Can anyone advise whats best for the Elite, my Elite sits so high from the back and it has 17'' alloys as standard.
    Many Thanks
    Elahi
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Only things I can think of are the drop links on the suspension which can be changed for Meyle uprated ones for the Saab 93 because they also fit the Vectra.
    http://www.ebay.co.uk/itm/Saab-9-3SS...item415cb0094e
    Genuine Vauxhall parts are pretty good when it comes to wear and tear - apart from the drop links and some other stuff. As long as genuine VX ones are being fitted they'll be fine. If you want to lower the car, 30mm Eibach springs are very good - will set you back about £150. It would be a good idea to change the shock absorbers though to ones from an SRi or GSi - these are designed for the lower and stiffer springs if I remember right. Failing that, Bilstein B4's are a good shock and will be fine with the Eibachs.
    Oct 2010
    Bedford
    Thumbs up
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    I do recall something about certain steering components being uprated for use with 19inch wheels, cant recall if its the steering arms/track rod ends or not...
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    Dean your right i think it was Cabby who had uprated bits on his Siggy
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    vauxhall do list a diff steering arm for cars with 19" alloys but not looked what the diff is,
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    probably just more robust.
  1. Apex lowering springs & shocks, they any good?
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2012, 10:34
  2. heavy duty droplinks
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2012, 13:42
  3. Lowering Springs Apex
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 07:56
  4. Where can I get some heavy duty rubber....
    By PeterVV in forum Styling
    Last Post: 20th November 2008, 22:17
  5. eibachs or jamex lowering springs ???
    By veccy22 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2007, 12:47
