Thread: Nearside rear footwell soaked
    Default Nearside rear footwell soaked
    Have scoured the threads here and can't find anything that matches my specific problem.
    I have 05 estate 1.9cdti and the REAR nearside footwell is soaked all the time, but the front footwell is dry.
    I have followed the info here and cleaned the scuttle drain, which incidentally was clogged.
    Would this have caused a wet rear footwell or would it be expected that the front well would be wet too?
    I am hoping it will dry out now but any advice or troubleshooting from folk with a similar problem would be appreciated.
    Last edited by bungeedood; 18th September 2011 at 19:11. Reason: to highlight specific area
    Aug 2011
    sheffield
    yes it would do i'm affaid on my second vectra c now and both have had the same problem you need to change the resistor pack ,
    Aug 2011
    sheffield
    oops sorry didnt read all your add properly no not had rear problems only front
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    have you had a look underneath the car for damage?
    Heater/cooler is fine, no damage under car, though I have spotted what looks like a screw in grommet of some sort directly underneath the rear footwell?
  1. nearside rear indicator
    By myelite150 in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2010, 17:42
  2. Rear Wheel Bearing (nearside)
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 22:06
