Results 1 to 10 of 21
Thread: Tech 2 help please
    Regular Member R2XPT's Avatar
    Scotland
    confused Tech 2 help please
    Hi guys I need help to programme my autolights/auto wipers and auto dim mirror, I've got a loan of tech 2 but can get the stuff to active, would anyone have some sort of user manual to activate the sensors/switch as I've spent hours looking thru and no option to activate?? Maybe it's just I'm not doing it right so hoping someone would give me step by step help on how to sort it??
    gwent
    Hi what system are you using When I did my auto dim mirror you need to go to rear body REC then variant config Look for auto dim mirror and set to present when you done that go out of the menu and turn it off and the car leave for 15 seconds so the car reset it self and it should be done the same as the auto lights as well.That's how I did when I used vaux com
    Scotland
    Quote Originally Posted by wayne10244 View Post
    Im in BCM ATM and entered in my security code, not it's saying quiescent current optimization either press inactive or active, which one do I press?
    Glasgow
    Theres no manuals mate the guys at vauxhall go on courses to learn how to use it.
    The word you have wrote "quiescent" is that correct? Someone posted on your other thread what control modules you needed to change did you follow this ok?
    Glasgow
    Now hardware all done. Going to tech2 section. You will need to program:
    UEC, set rain sensor to present
    BCM, set auto headlight switch to present
    REC, set rain/light sensor to present
    REC, set auto dimming mirror to present
    Copy/Pasted from the above mentioned how 2.
    gwent
    Come out of that and start from Beginning Menu put your car model & year Then next to body module rear REC then variant config scroll down to what you are after and to it on to present do this for the mirror and the lights and wipers and press save now switch of for 1min then turn back on Oh I forgot about that you need to put your code in before you can alter anything
    Scotland
    Right guys pressed what I wanted to present, turned off tech 2 and locked the car for 5 mins, started car up and tried the stuff nothing works, plugged tech 2 back in everythig has been set back to not present, why is that??
    gwent
    Did you to press program this will keep all the new settings
    Scotland
    Yeah mate, it's the BCM that keeps resetting now, before a go on to it do I press inactive or active?
    gwent
    Press active
  1. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  2. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  3. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  4. Tech 2
    By WHOOSH05 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 16:54
  5. Tech 2
    By cooky516 in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2008, 11:36
tech 2 vectra rain sensor
quiescent tech 2 help
