Thread: Replacement Ultrasonic Module
    Aug 2011
    Solihull
    confused Replacement Ultrasonic Module
    Can anybody help, I've searched for related posts but haven't found the answer. Have a 56 plate 1.9CDTI 150 Estate, damn Safeguard warning on display every time IGN on. Told by local stealers that new u/sonic module needed and quoted £216. Anyone know where I can buy one? Quoted price is a joke.
    the stealer is wrong , the usual cause of this problem in an estate is either the rear tailgate heating element is broken at some point because this also runs the alarm
    or one of the thin back wires on the rear side windows has broken as this is also for the alarm
    Engine : 1.9 CDTi
    I have one for sale if it is that you need.
    Bristol
    My fault was the loom broken accross the roof I ran a seperate wire to fuse 21 in REM. I also have an ultrasonic for £25 posted.
    Aug 2011
    Solihull
    I've checked the rear side windows and bonnet switch, all OK. Didn't know about the heated rear window, will check that.
    lee gsi: what's your price??
    Thanks both
    Engine : 1.9 CDTi
    £12 delivered as you need to swap the trim over (Unclips): http://www.vectra-c.com/forum/showthread.php?t=142318
    Aug 2011
    Solihull
    Thanks lee gsi. Need to check heated rear (which I think is OK) and I'll let you know.
    Cheers Mate!
    Engine : 1.9 CDTi
    I had the safe guard message too and bout that sensor to find out one of the rear fuses was missing
    Aug 2011
    Solihull
    Hello lee gsi,
    Been waiting for the forum to come back online. I've checked everything out and all seems OK. I can only assume it as actually the ultrasonic module. I'll buy your spare if it's still available. How do I go about buying it?
    Thanks.
  1. Cim Module
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd February 2011, 16:00
  2. MOSS MS704 Ultrasonic sensor kit
    By MysteryElite in forum General items for sale
    Last Post: 29th May 2009, 14:26
  3. CIM Module
    By phil79 in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2008, 11:32
  4. CIM module
    By rayvo-gsi in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2007, 02:12
repair cim module vectra c
replacement of ultrasonic module
