Thread: Ex VAG
    Sep 2011
    Sipson
    Default Ex VAG
    Just joined yesterday. Had been looking for ages at a replacement for my 2000 Seat Toledo 1.9TDi, had actually settled on a saab 9-3, but as my budget is restricted to £2500 the options and spec I wanted meant high mileage.
    I found a 2003 Vectra with the 2.2Dti SRI in blue, with 89000mi and a 2 year warranty. They serviced it is getting an MOT tomorrow for me and I will collect after work tomorrow.
    I did notice on the test drive that it was lacking in power below 2000rpm, something I just figured was because it was not as a good as VVT in my Toledo, but after reading some posts on here sounds like it might be the EGR.
    So, I will get some 10k boost to run through it, I know it worked wonders on my Toledo, so hopefully will atleast help prolong and actual failure in the short term.
    But I plan on maybe getting it chipped anyway, so I might look at the decat and EGR program from the ECU.
    So, can't say I'm a happy owner just yet, but hopefully this time next week I will be loving it.
    Regular Member Ralphwells1967's Avatar
    dartford
    Hello and to vec c m8
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Welcome to vec-c m8
    and still loving it
    Regular Member Innes's Avatar
    Plymouth
    Quote Originally Posted by krisby View Post
    Welcome to the forum.
    10k is ok if its been done regularly but if it hasnt then you'd be better off mannualy cleaning the inlet manifold. See the link in my sig. Before that though the boost sensor could probably do with a clean. You'll probably notice a difference and its easy enough to do withcarb cleaner and a tooth brush.
    Other things to look out for on the DTI are degraded vacuum hose connectors and split intercooler hoses. Vauxhall used crap materials and the oil vapour eats the hose from inside out. Most people replace the vacuum pipes with silicone ones from eBay for £6 and the intercooler hoses are also available for £45-60 each but I'm currently working on a hose company to make them cheaper and vectra-c.com members will get discount when they've made the patterned part. Here's a pic to show you the usual suspects:
    Sep 2011
    Sipson
    great, thanks for that, I'll defo clean the boost sensor manually, but will still put a can of 10k through, only cos after seeing the crap that came out of toledo, for the first 3/4 of the can, I knew it had done good, so even if it makes no difference on the vectra atleast I know it should be clean (er) than it is.
    I'll certainly be hunting on here for maintenance tips, used to service my own petrol cars but haven't actually got round to doing a service on a diesel, my only fettling was cleaning the EGR and replacing the MAF on my toledo.
