Thread: F17 Final drive / diff
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default F17 Final drive / diff
    Hi,
    Does anyone know if the final drive / diff is the same between F17 gearboxes, ie Vectra C cable selector and the older rod selector mechanism?
    On closer inspection of mine, it seems that the gearbox itself is OK, just the side gears are totally shot.
    As I can't get a F17 with cable selector, I was thinking of just removing the diff and replacing with a good unit.
    I also wonder if any other gearboxes fit the same diff unit?
    STE
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Mr Haynes says F17 comes in either Wide or Close range versions.... but beyond the ratio differences gives no differences between the physical casings and controls.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Just to complete the story if anyone searches at some point in the future.
    I managed to get an older F17 gearbox with the rod selector type. After swapping the selector assembly for my cable type and also changing the clutch release bearing (as the release bearing has a different part number on it and the external tube connector is different) I fitted the older gearbox and it all works fine. Cost me £90, got it from Derby this morning and fitted it today.
    Jul 2009
    The Rift, Cardiff
    Good result and usefull info for 1.8 owners.
  1. Diff gone!!!
    By bigbnlr in forum Engine & Drivetrain
    Last Post: 22nd March 2012, 20:59
  2. f17 final drive
    By davidallanmcdonald in forum Engine & Drivetrain
    Last Post: 10th January 2012, 06:24
  3. f17 final drive
  4. final drive cover plate
    By 5008tony in forum Engine & Drivetrain
    Last Post: 25th March 2010, 22:31
  5. Gearbox and Final drive ratios for V6 CDTI ?
    By diesel dog in forum Diesel Engine related
    Last Post: 15th January 2008, 17:13
f17 gearbox are the same as an older f17
