Results 1 to 3 of 3
Thread: vectra 2.2 sri direct fuel pump problem
    Aug 2011
    bridlington
    Default vectra 2.2 sri direct fuel pump problem
    hi, just been told my vectra 2.2 sri direct needs another fuel pump even though it got one fitted 18 months ago(continental one)....is it worth contacting vauxhall or not in anyones previous experiences....next question is it easy to fit my self as lookin at the pump it sits right at front/top of engine......
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    easy to fit mate, but who diagnosed it? have you checked regulator/sensor
    Jun 2006
    Kirkintilloch, Scotland
    Very easy to to fit fuel pump.
    http://www.vectra-c.com/forum/showth...t=95693&page=3
    However given that you have recently fitted a new pump I would as Mark suggests strongly suspect the regulator.
    Be aware that the regulator is subject to a recall - check with your dealer - and it could be replaced free of charge.
    Otherwise replacing the regulator is again a very easy job and the instructions in the Haynes manual are easily followed. The cost of the regulator is just under £100.
    Dave
    Posted just prior to his Australian odyssey!
  1. Signum 2.2 `Direct' - fuel injection pump problem
    By omega2498 in forum Engine & Drivetrain
    Last Post: 20th August 2015, 19:06
  2. Possible Fuel Pump? Vectra 2.2 Direct
    By betty02 in forum Engine & Drivetrain
    Last Post: 17th March 2011, 00:49
  3. Vectra C direct 2.2i fuel pump failure
    By davidu in forum Introduce yourself.
    Last Post: 19th September 2010, 23:58
  4. H.p fuel pump pressure regulator problem 2.2 direct
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 18:06
  5. Another Signum 2.2 Direct fuel injection pump problem
    By Whoosh in forum Engine & Drivetrain
    Last Post: 6th December 2007, 12:06
vauxhall vectra 2.2 fuel pump problems
vectra 2.2 direct fuel pump
fuel pump check vectra 2.2
vectra fuel pump on a 2.2
vauxhall vectra 2.2 direct sri problems
Vectra 2.2 sri petrol electronic fuel pump
vectra c direct 2.2 fuel dumper
vauxhall vectra 2.2 sri running problems
vauxhall vectra 2.2 direct fuel pump
vauxhall vectra c 2.2 direct fuel pump
vectra c direct fuel pump
vauxhall vectra 2.2 petrol fuel pump
vectra 2.2 direct fuel pump problems
where is petrol fuel pump on a vauxhall vectra 2008
vectra c 2.2 direct fuel problem
vectra 2.2 direct not starting after pump replacement
vectra 2.2 hp fuel pump
vectra 2.2 sri fuel pump problems
vectra vauxhall 2.2i fuel problem
Who need kakara with his vectra direct belgium
vauxhall vectra 06 2-2sri starting problems
vauxhall vectra direct 2.2
opel signum 2.2 direct probleme fuel pump
