Thread: cim help
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    Default cim help
    first sorry if this has been covered but i need help i can not get the security code to be accepted by the cim,i can access every other module but this one all info it correct vin number etc,and i can clear the faults but it will not accept the security code so i can activate the stalks,,also has a wait time of 40 mins how do i get round this ?do i leave it with ignition turned on for 40 mins any help welcome ps using op-com with 2010 sofware
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Leave ignition turned on for 40mins, no way around security code. Make sure ignition is on when trying to enter code for the CIM. Could be a replacement CIM at some point, think the VIN etc etc can be set without security code..
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    thanks for your advice
    Bristol
    Default cim
    If you keep going into any modual on the car 2 much at one time. It will lock you out. And there is no way of getting into it. You will probably need another CIM .This is what I have been told By the Stealers. I will be intrested if leaving the ignition on for 40 mins works.
