Results 1 to 2 of 2
Thread: Help fitting double din head unit... aftermarket cage question?
    Regular Member Deann's Avatar
    Mar 2011
    England
    Default Help fitting double din head unit... aftermarket cage question?
    Hey guys
    Just ordered a double din and ordered this cage with it
    http://www.caraudiodirect.co.uk/con-...xhallopel.html
    I can't for the life of me figure out how it works, obviously it has some sort of locking mechanism on it so that the head unit is anti theft but I can't get my head around the concept of how this works?
    Does anybody this early in the morning have the answer
    gwent
    Thumbs up
    Hi it's really easy the gold colour clips locate into the two brackets that have the hole's on this screws on to the side's of your head unit the nearer you fit them to the front of the head unit the better because it won't stick out so much next fit the cageo in to the surround plate then slide into your dash and bend the tabs to stop the cage from sliding out then wire your head unit make sure that it is working if so slide it in making sure that you don't catch any wires and fit the outer face plate that it all done
  1. Help with fitting an aftermarket head unit.
    By alembicbassman in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2010, 19:29
  2. Help - Fitting a Double din Head Unit
    By Q22ube in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2010, 13:32
  3. Head unit cage
    By sithompson in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2008, 19:05
  4. What do u lose on display when fitting aftermarket head unit?
    By Rikkiola in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2006, 22:57
double din into vectra c doesnt fit
