Results 1 to 10 of 14
Thread: Vec C owners with the Irmscher back box.....
    Default Vec C owners with the Irmscher back box.....
    Don't suppose you could measure the dimensions of the tail pipe and post it here could ya?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The short tip is 16cm long along the top edge.
    The long tip is 25.5cm long along the bottom edge.
    These measurements were taken from the box to the end of the tip not just the chrome part.
    The Signum tips will be different as they come out at a greater angle to the Vectra tips.
    Each tip is 11.5cm wide and from the top edge of the small tip to the bottom edge of the long tip it measures 24cm.
    HTH
    Steve
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Thank you Steve
    Appreciate you checking that out for me. I'm looking into getting a full stainless system from MIJ. They have a set of tips which look very similar to the Irmscher pipes. Also want the rear splitter which the pipes are designed for. Wonder if they will fit and look as good as standard.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No probs. Yea I've seen those tips but don't know how big they are, they look pretty similar.
    You can also but copy Irmy skirts from ebay but couldn't tell you how good they are.
    Those are the ones, look really good. Only noticeably different thing I can see is that the genuine Irmscher pipes are offset. The MIJ ones come out at equal length. This makes me think they might not sit in the Irmscher splitter correctly. Will check out the ebay splitter.
    Thanks for the pointer.
    Woodbridge
    I dont see why they would not fit, I will check mine tomorrow but I am sure there is quite a bit of a gap.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    It should fit fine, remember the only people that will know the difference are a very select few, after all they are only available for the Vec/Sig so no other VX driver will know unless they get close and make a point of looking for the i stamp on the end of the tips.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    if it helps i have powerflow square quads in the irmscher rear diffuser, i will add a pic for you to see.....
    Midlands Mod Shop - NFFC.
    Trim : Get a
    not the best or most recent pic but should give you a general idea...
    HTH
  1. irmscher back box
    By MURDO in forum Vectra C / Signum Troubleshooting
    Last Post: 15th September 2011, 09:26
  2. irmscher back box on
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 22:31
  3. irmscher back box
    By macka85 in forum Petrol Engine related
    Last Post: 11th January 2010, 22:06
  4. Irmscher Dual Exit Exhaust Owners...
    By damian s in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 21:36
vectra c irmscher back box
