Results 1 to 2 of 2
Thread: Problem box
    Sep 2011
    norwich,norfolk
    Default Problem box
    Hi folks,got a vectra c 2.2 litre petrol,Gearbox is okay to start with but then stays in fifth gear,if I push it over into manual mod it still stays in fifth,turn engine off and restart,in manual mod no fifth gear but in auto its okay briefly then does it again,management light is on,fault is sticking clutch,torque converter,this only started after fluid change.
    No contamination appears to be present.Dealer is saying gearbox fault as only one fault code is ever present,is he right.
    Have asked local garage who did first fluid change to drain and refill again with genuine VX fluid,they have said they will remove valve chest and clean it as well,does that sound plausible.
    By the way mileage is 80,000
    Sep 2011
    norwich,norfolk
    Update on my problem folks,gearbox is faulty,changed fluid and still the same,fluid had only been in about a 1000 miles,and was black and burnt.so looks like gotta bit the bullet and replace box.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
