Results 1 to 3 of 3
Thread: Couple of quick 'where' questions
    Sep 2011
    Halifax
    Trim : Elite Estate
    Engine : 1.9cdti 150
    Default Couple of quick 'where' questions
    Right, talk about timing. I join this forum and a mate's 16v CDTi stops working.
    Turns over but will not fire. Checked timing, OK. Checked cam sensor,OK.
    But where is the Crank sensor located - I cannot see it.
    and
    where is the fuel cut-off switch? (05 hatch).
    Having to check everything as I think of it as I wasn't about when it died and my mate is as technically-adept as a dish-cloth.
    Any help would be much appreciated
    The crank sensor on the 1.9 diesel is on the rear of the engine block in the area below the starter motor. There is no fuel cut of switch as far as I know but there is a pump mounted in the fuel tank that you should be able to hear running when you switch on the ignition.
    Sep 2011
    Halifax
    Trim : Elite Estate
    Thanks Rampala
    Checked fuel and it is being pumped to the filter. I have now gained a list of diagnosis codes so will try to see which one comes up in the morning.
  1. a couple of little questions
    By kvraider in forum Vectra C / Signum Troubleshooting
    Last Post: 21st December 2011, 23:24
  2. Couple of quick air-con condenser questions
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2010, 22:42
  3. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
