Thread: P0615-02 Starter relay circuit voltage (fault code any help)
    Regular Member eaglepva's Avatar
    Up North
    Default P0615-02 Starter relay circuit voltage (fault code any help)
    Just had the codes read on the signum and came back with the following
    P0615-02 Starter relay circuit low voltage
    Any help on where this relay is or what to do.
    Up North
    Bump
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    What symptom are you getting. Does the car start?
    If it turns over then i can't see starter relay causing a fault
    Up North
    Car starts fine, on cold morning it sometimes runs a bit lumpy but a little rev and its fine, also get some smoke out the back on start up.
    Had the codes read the fella that done them said that the starter relay could be opening and closing while driving bringing the glow plugs on?
    I think the car needs new glowplugs but just wanted to get some opinions before doing them.
    Car is a dti
  1. p0480 fault code cooling fan 1 circuit malfunction
    By Miketwinny in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2011, 22:31
  2. P0380 - Glow Device Circuit Low Voltage
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 5th March 2011, 01:13
  3. Replies: 9
    Last Post: 15th October 2010, 17:57
  4. fan relay circuit 3
    By cruicky27 in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 13:26
  5. P0381 Glow Device Circuit Low Voltage
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 13:09
Opel P0615
Vauxhall P0615
vauxhall p0615 tarter relay fault
vauxhall astra p0615
snap on fault code P0615 vauxhall
fault code P0615 on vauxhall vectra 2007
p0615 vauxhall
p0615 opel vectra
opel P0615 06
astray diesel starter relay p0615
vectra c starter relay low voltage
p0615 starter relay circuit
p0615....starter relay circuit
p0615 02 opel
p0615 opel
https:www.vectra-c.comforumshowthread.php147312-P0615-02-Starter-relay-circuit-voltage-(fault-code-any-help)
vectra c starter relay fault
