Thread: bulge on rear tyres...egg shaped??
    Regular Member marky2027's Avatar
    Northumberland
    Default bulge on rear tyres...egg shaped??
    MOT yesterday...nail in tyre...been to local tyre place today..nail in one and screw in the other. Then he went on to tell me that the rears had a bulge on the tread and sounded like they were effectively egg shaped and worn on the inside. They have droned for months now and have had this before as my tyres have worn unevenly and has stopped with new tyres. I have never been told that the tyres have been mis-shaped though. I looked through the threads and found that this irregular shape is fairly common and due to the suspension set up. The tyre bloke said he had a few like this on the vectras and he recommended new tyres.
    Thinking now...are these mis shaped tyres really dangerous? Should I change for new or just get punctures repaired (about 5mm left). They must have been this shape for months now
    East Ayrshire
    Trim : SRI XP1
    yes change them. it will seriously affect their reliability as well as vehicle characteristics. I'd recommend getting a geometry set-up aswell and this may resolve it in future. Get all your bushes etc checked aswell
    Northumberland
    I have had the car over 4 years now and will be changing the car next June. I am trying my best not to spend too much on it because of this. I have thought about the geometry check before but will not be getting it done now (cheers for advice though)' Just wanted to know if the tyres were really dangerous in this state or is it just a case of them droning on
    East Ayrshire
    Trim : SRI XP1
    you can get it done for £40, its not a massive amount, you could end up going through another set of tyres prior to then if its that bad. Failing that tho, you could always just put a set of budgets on to get you through
    Northumberland
    Thought it cost loads more than that to be honest as i had 4 wheel laser alignment done and it cost about £40. With all the adjustments/measurements I was sure it was nearer £100
    East Ayrshire
    Trim : SRI XP1
    Last one I had done was on a hunter equipment thing, cost £38, got a before and after printout etc Was definitly worthwhile even though i had to travel 60miles to get it done! Unless you're using the wrong load rated tyres then there must be something with the set-up. Maybe someone nearby could have a look if you don't do your own work
    Northumberland
    Is that with camber adjustment etc?? I always check the load and speed rating and they are exactly right
    East Ayrshire
    Trim : SRI XP1
    yeah, that included the lot. Was well inpressed as i seen most places charge about £100. It was a company called pro-grip i used, try www.alignmycar.co.uk and it will show your nearest centre
    Northumberland
    Don't know how you got it for that price. I have just checked the website for my nearest place. Full 4 Wheel Alignment (all adjustments inc camber, caster etc) £99.99 +vat
    East Ayrshire
    Trim : SRI XP1
    Ouch thats alot. Maybe phone around a little bit. The guy I use is a specialist in alignment. He takes no more than 1 hour to do it, but always does a cracking job, Most of the guys up here that have track cars use him aswell
  1. Odd shaped spanner
    By Big Sig in forum Comedy & Humour
    Last Post: 18th January 2011, 21:56
  2. Rear tyres
    By stugga in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 16:01
  3. Replies: 22
    Last Post: 25th April 2008, 08:33
  4. newly shaped signum with air vents
    By butcher-boy in forum General Chat
    Last Post: 8th June 2007, 19:06
  5. No Large Intercooler shaped boxes :(
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2006, 22:37
