Thread: Radio Metal Cage
    Jul 2010
    Default Radio Metal Cage
    Still trying to fit an aftermarket CD/Radio to my 2003 Vectra. Got the unit to work now (thanks to help from this forum) but now need to tidy up the fitting. I have a plastic mould that reduces the gap to a standard unit but do I need to take out the old metal cage ? I have removed one torx screw at the rear of the cage but it still is not wanting to come out. I can see that there are indentations all round the edge of the cage which appear to hold it in position but is there anything else holding it ?
    The aftermarket CD/Radio sticks out from the front of the dash and so I think I need to remove this cage to give me more depth and also to enable the cage from my new unit to fit. Is this correct please ?
    All help gratefully rec'd.
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Yeah the original cage needs to come out. On the bottom of it it's got a line runs up the middle. I bent mine upwards along this line. I was quite brutal with it too but it came out eventually with a bend and a tug. I bent it back into shape when it was out of the car so no harm done.
    Dave
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yes I bent mine aswell and give it a good pull
    Jul 2010
    Default Done
    Thanks again folks. Brutal is the word !
    Bent, but no doubt can be straightened if required !
  1. Radio cage and signle din fascia
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2012, 12:50
  2. can the radio / switch cage be replaced
    By Dal5band in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2012, 11:03
  3. JVC radio cage
    By ropa83 in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2011, 19:46
  4. Removing the Radio / Stereo cage
    By Silly Car in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2010, 23:40
  5. Single DIN Radio Cage
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2005, 20:51
vectra c metal radio
vectra c radio removal cage
remove vectra radio cage
remove radio cage vectra c
