Thread: 1.8 fuel filter ?
    scotland
    Default 1.8 fuel filter ?
    where is it located ? done my oil an filter , plugs an air filter , panel filter , now just the fuel filter where is it located ?
    cheers
    north east
    under the rear drivers side wheel attached to the tank .... I think
    scotland
    ta , guess its jube clips unless I got the special crimp clips to change it ?
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Not Jubilee clips. Its the usual Vauxhall clips. You need 2 small screwdrivers to push in the clips at the same time as pulling the pipe off. Or easier option buy a set of pliers to do it.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    it is attached to the side of the fuel tank but in a plastic ring sleeve that you slide it out of. You wil need some flat blade screwdrivers to insert on the pipe clips to free them up to allow them to be unclipped from the filter though.. be careful not to spill petrol on your face if you are directly under it as it will have some in it.
    btw the tank and filter is under the O/S passenger seat not the wheelarch so you can get to it very easily but its best to use a jack and axle stand to get better access..
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Fuel filter help
    By wolvesdaz in forum Engine & Drivetrain
    Last Post: 4th March 2011, 10:47
  3. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  4. fuel filter
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 23:27
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
