Thread: Who's used the scorpion pre-cat decat?
    Sep 2011
    MILTON KEYNES
    Default Who's used the scorpion pre-cat decat?
    Hi all,
    I've just cut the centre cat out of my system, and replaced it with a piece of 400mm x 57mm stainless (£5!), nicely mig'd all the way round.
    Felt the difference in torque immediately and am now looking to replace the pre-cat.
    Scorpion seem to be the only people to offer the precat decat pipe, it's £150 so I thought I'd see if anyone has tried it first! Dont want to spend that money an waste probably 4 hours fitting it if it has an adverse/no effect.
    Any help/advice would be great thanks, Dave.
    2006 SRI 150 1.9 CDTI VECTRA (No dpf model)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have it on mine plus a few other mods
    Improved the sound of the exhaust and seemed to improved power
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Engine : Z19DTH
    Mileage : 166000
    ive got an empty precat on mine (merikiito's old one coincidently) that i just knocked out the insides of and it was a great improvement on power and fuel economy, i will get the scorpion one at some point but the redneck approach will do for now
    edit: on a side note you'll be happy to know lee ive now got an airbag and have fitted that wheel and its lovely lol
    Regular Member R2XPT's Avatar
    Scotland
    Hi guys is it easy enough to remove the precat on the cdti? And how long to remove/fit?
    Sep 2011
    MILTON KEYNES
    Option1: If you haven't got a ramp then it's easier to take the bumper, front panel and strip out the rad/IC/condensor out to get to it, and then you'll have loads of room.
    Option2: Otherwise if you get under it, take off both undertrays, you can almost see where it bolts to the turbo, and you can spend some time stuggling and just get it off...
    When I do mine I'll do Option 1, and make the most of having it all stripped, -hybrid turbo, front mount IC and precat decat.
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Engine : Z19DTH
    Mileage : 166000
    tbh if you loosen the heat shield and have got a flexy head ratchet spanner with the help of some liberal swearing its not too bad and getting back on isnt too bad its just a bit of a juggling act
  1. For Sale: Scorpion PreCat DeCat Down Pipe for 1.9CDTi 150
    By jimbojetset in forum Parts for sale
    Last Post: 4th December 2011, 22:20
  2. Sportex or Scorpion
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 01:48
  3. Scorpion Fitted
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2011, 18:33
  4. to decat or not to decat a gsi - is it worth it?
    By TimTay in forum Petrol Engine related
    Last Post: 21st January 2011, 21:25
  5. Scorpion Exhaust?
    By Mark2.2 in forum Styling
    Last Post: 20th July 2009, 19:46
