Thread: Dash Lights
    Aug 2011
    Berkshire
    Default Dash Lights
    Just noticed tonight that all my lights for dash, buttons, heater etc are working apart from the headlight switch (fog and adj buttons) is there a seperate fues for this? I would be surprised if it is a fues as they are only LED's and take very little current. Any one know what the likley problem could be?
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Is the light switch not turned on with the ignition?
    Whereas the remainder of the panel lights are operated when the lights are turned on.
    Illumination for the light switch is controlled by the BCM..
    So thngs to check are..
    Turn on the ignition, and see if the light switch lights up
    Check the wire from the BCM to the light switch.. cannot remember the exact pin number.. but can look this up.
    Faulty LED within the switch unit... very unlikely as there are loads of them.
    Loose connector (12 pin quadlock) of faulty, damaged or snapped wire in the connector. Disconnect, and then reconnect the plug to check.
    Aug 2011
    Berkshire
    Robsey, Spot on, thanks. They are switched on with ignition only and not just the light switch without the key in. I noticed this morning. Nearly bought a new switch unit of fleebay as well, just in case.
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Glad to be of help
  1. Dash lights
    By stuk2000 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 21:51
  2. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  3. Dash lights
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2010, 22:42
  4. Dash Lights???
    By dave04 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2010, 15:32
  5. Dash lights?
    By Messenger in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 21:29
