Thread: vectra 2.0 turbo stiff gear help
    Regular Member matrix1979's Avatar
    Aug 2007
    NORFOLK
    Default vectra 2.0 turbo stiff gear help
    Dont know if any one can help me but i think there some thing up with my 2nd gear . when i pull away in 1st which is ok its when you go down to 2nd it seems to bit abit stiff or feel likes its going to crunch but doesnt is there a quick fix to this or ? Im pritty sure its not normal .any advise will be great cheers .
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    does it do this all the time i.e. when cold and when warmed up? has it always done it? how old is the car and how many miles has it done? Have you ever changed the gearbox oil since you owned it?
    Aug 2007
    NORFOLK
    I have only had the car a week so its under warranty , its deffantly doing it when cold not sure when hot ill have to check this , the cars 2007 with genuine miles 45 k on the clock ,not sure if gearbox oil has been changed but wouldnt it do it in all gears if it was the gear box oil ?
    Aug 2007
    NORFOLK
    its stiff when u pull the lever down into 2nd gear
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    Mine did this I changed the gear box oil and it is alot better now it's a common fault apparently with turbo box
    Aug 2007
    NORFOLK
    oic ill have to try that then good heads up caveman/danny
    dont mean to sound a numty but where s the drain plug and filler point situated dan ? and how much should u use to refill?
    scotland
    this might be too simple but I had this prob , prize off the gearstick gator and look in , mine had a wire with a brown connector on it that was fowling the gear change , not sure what the connctor block is for but its going nowhere . (maybe rear 12v outlet) .
    Jun 2009
    South Coast
    check under the gator as advised first as that must be worth checking..
    for reference purposes you should know that your engine is known as a Z20NET and the gearbox model is known as an F40..
    Changing the dearbox oil is shown here >>>> http://www.vectra-c.com/forum/attach...4&d=1313744713
    I used Castrol SMX oil from Halfords to do mine. Let us know how you get on.
    Aug 2007
    NORFOLK
    Exclamation
    Quote Originally Posted by Caveman_nige View Post
    I have checked under the gaitor all seems fine so going to try the gearbox oil change next . How many litres to I use to refill was told 3.2 litres is this correct ? Was also advised by my local Vauxhall specialist it could need the gears re aligned . Does any body have a step step on realigning the gears ? Any how I'll report back on how I get on .
    Aug 2007
    NORFOLK
    just an update i have changed the gearbox oil but still have the same problem ,i think its improved it abit and its worse when the engine is cold , so going to try and realign the gears next will keep u all updated .
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Stiff Gear Change
    By John Bishop in forum Engine & Drivetrain
    Last Post: 1st June 2012, 16:43
  3. Stiff Gear Change
    By sheddy in forum Engine & Drivetrain
    Last Post: 24th February 2012, 12:07
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Stiff gear changes
    By James7 in forum Engine & Drivetrain
    Last Post: 17th April 2007, 19:45
modify 2.0 diesel turbo vectra
