Thread: Wheres my drain plug
    Mar 2011
    dunfermline
    Question Wheres my drain plug
    was going to change coolent on my 1.8 petrol but for life of me could find radiator drain plug where is it
    Helppppppp
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Should be on the o/s of the raidiator, if not just take the bottom hose off.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    i just changed the rad on my wifes car, I can confirm it is on bottom o/s end of the rad, you can get to it from underneath if you need to. It has a plastic flat handle to get hold of if you know what i mean
    Mar 2011
    dunfermline
    think so is it black by any chance and made of plastic
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    yup..... grip it between thumb and forefinger and turn... I even went out and checked it about 15 minutes ago just to double check.. its defo there...
    Mar 2011
    dunfermline
    cheers m8 was looking for a metal bolt
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Got what looks like a slight coolant leakage o/s front at bottom corner of radiator on our Facelift Club with the Z18XE non VVT Engine......6 years old & 59+K miles on the clock...
    Just a teaspoon a week or so at present on the ground underneath the car.......
    Found this thread useful as I was wondering where the drain tap was....
    Hope it's the tap/gasket leaking & not the radiator...
    Will update when I've had chance to check it....
    Glad I found this thread...
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Quote Originally Posted by Tony W View Post
    Got a mate who services the car to look at it while checking over a couple of other things I was querying.....Radiator was leaking...not the drain tap
    He recommended adding 'K - Seal' to the cooling system as the leak was relatively minor...small amounts....about a teaspoon or so per trip....
    It's cured the leak....£9.00 from a motor factors where I work part time...vs £70.00/80.00 plus fitting for a replacement radiator.....
  1. Wheres the fault code plug?
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 14:00
  2. f40 drain plug access
    By justin32 in forum Engine & Drivetrain
    Last Post: 26th November 2011, 15:10
  3. Gearbox oil drain plug
    By big nath in forum Engine & Drivetrain
    Last Post: 15th February 2011, 18:13
  4. Magnetic Oil Drain Plug
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2009, 14:36
  5. oil drain plug ?
    By dmoffat in forum Engine & Drivetrain
    Last Post: 17th June 2008, 10:27
vectra c radiator drain plug site:www.vectra-c.com
