Thread: Retrofit headlight washer plug
    gwent
    Default Retrofit headlight washer plug
    Hello does any one know had to retro fit a headlight washer plug because i had a look i don't had it but i got the relay and fuse in the engine bay fuse box this is on a 2007 sri
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yes I have done it, its pretty easy actually. Are you sure you aint got it, weird that the relay is there.
    gwent
    Well had look this morning to see ifi had it but all i have is the screen washer plug and the level check sensor could not see the plug for the headlight washers
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Im nipping to the scrappys Monday or Tuesday, if you want I could see if I can get a plug.
    gwent
    Hi that would be great what do i need all together to fit yhe plug
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Nothing. I will remove the plug with cable and add an earth for you. Then all you have to do is remove the fusebox under the bonnet and add the wire to slot 50 in the big multi plug(it just pushes in, connect the earth to the one of the factory earth points on the inner wing and bobs your mother's brother. Its a lot easier than it sounds. Kenp sent me a link on how to do it, ill see if I can find it.
    gwent
    Thanks very much let me know how much for the part and pm you for the cost thanks again
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Sorry its slot 26, not 50(thats for the heated winscreen washer jets )
    Heres the link that Kenp gave me, its in Danish but as they say pictures tell a thousand words.
    http://danborg.org/opel/Forlygtevasker.pdf
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes i was missing the plug to , and retrofitted it, and its my page his linking to
    gwent
    Just getting all the parts together so I can fit now getting the extra plug from the seller of the headlight washer bottle
  1. RetroFit Auto Headlight Switch
    By NealM in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2011, 14:05
  2. Headlight wash retrofit (facelift)
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2010, 10:28
  3. cdti sump plug and washer?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2008, 23:40
vectra c headlight washer retro fit
