Results 1 to 10 of 25
Thread: Fitting headlamp bulbs
    Regular Member Flyingkiwi's Avatar
    Jun 2006
    Mytchett, Surrey
    Default Fitting headlamp bulbs
    Right then...
    I have seen all the various threads about people replacing their main beam bulbs, etc, and after realising how dismal my standard ones are, have decided to replace mine. (main and side lights)
    The question is, how exactly do you replace them? i.e. I read the How2 on headlamp replacement/removal, but cannot recall seeing anythng about just bulb replacement. Do I need to follow the same procedure??? (This is where I need the non-existant Haynes manual...)
    Sorry if this question sounds too basic.
    Any advise/assistance would be gratefully appreciated...
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    Its dead easy m8 the passenger side you unclip the water bottle neck wiggle it from side to side & pull at the same time to remove. The main bean there's a rubber cover remove this then twist & pull the block. unclip the loom block from the bulb & there's a plate. fit the new bulb on the plate, plug the loom back in & fit unit back in. High beam there's a plastic cover to the left undo this & remove & refit the new bulb the same as the main beam. The side light bulb is located just below the high beam all you do there is twist & pull.
    The driver side is the tricky one because of the airbox. but its all done the same way you just hav'nt got that much space to move about.
    Jun 2006
    Mytchett, Surrey
    Cheers Madgunner...
    Simple, eh??
    Have a feeling the air may be a bit blue around my neck of the woods this coming weekend...
    Quote Originally Posted by Flyingkiwi
    Cheers Madgunner...
    Simple, eh??
    it's just a bit of a fiddle getting to the high beam but if you got small hands....... Oh & make sure you DO NOT touch the glass on the bulb's m8 have fun
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    I took the airbox out and completed the job in about half an hour mate ... removing the airbox gave me loads of room to see exactly how the bulbs come out and go back in and therefore made the passenger side easier with the tight space.
    This was my thread when I did mine: http://forum.vectra-c.com/showthread.php?t=13230
    Dave
    Yea i done the passanger side first but the facelift vec is a bit tighter space anyway aint it m8?
    Jun 2006
    Mytchett, Surrey
    Cheers again guys...
    Am starting to wonder if it would be easier buying the bulbs, and asking my local non VX garage down the road to fit them for me...
    I have have a habit of turning a five minute job into a nightmare! At least I'm honest....
    either that, or buy them and wait till the next meet and i'm sure someone there will pop them in for you..
    Jul 2006
    Cheshire
    Quote Originally Posted by Gsi3.2
    For sure I know I would happily do this for you ... just give willing attendees prior warning so they know to bring Torx Drivers (or bring your own )
    Jun 2006
    Mytchett, Surrey
    Good idea that Mark, thanks.
    Problem is tho...and I hate to admit it...I nearly had an accident on the way home from Luton the other weekend due to my poor lighting. That's what identified the major shortcomings of my current bulbs. To be honest, am not sure if I can wait until the next time I can make a club get-together...especially as Winter is coming.
    I reckon this VX has got the worst headlight quality out of the five I've have to date...
    I will get them done this weekend...
    Cheers again.
  1. Which uprated headlamp bulbs?
    Last Post: 14th February 2012, 19:43
  2. Headlamp Bulbs
    By davieboy1976 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 11:22
  3. F*£$%^^ Headlamp Bulbs
    By Caterman in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2006, 17:46
  4. headlamp bulbs
    By Dave F in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2005, 16:00
  5. Headlamp Bulbs
    By ion in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2005, 07:59
