Thread: Tyre Presure for non standard 18's.
    Full Member coldo's Avatar
    Scotland
    Default Tyre Presure for non standard 18's.
    Hey all,
    I have a set of 18" Vaxuahall Astra Penta's on my vectra at present. I was trying to work out what I should be filling them to but can't find a recomended figure for the old girl... At present I am running them with 36 psi in each tyre.
    The tyre size is 225/40R18
    C
    West
    As a rule just double the rim size
    Scotland
    Ah... 36 PSI then.... Result...
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    autodata cd says 33 in all for the 1.9 cdti
    Scotland
    Quote Originally Posted by cossiejay View Post
    This is where my confusion is comming from as the wheel size on the Astra is different to the Vectra. I think from memory the 225/40/R18 is the Astra size (and what I fitted to the Vectra) where as 18s on the Vectra are 225/45/R18 (although I may be wrong here...)
    Mine is the 1.8 also...
    I guess filling them to 36 is reasonable given the wheel size as per the advice earlier...
    Norwich
    Trim : SXi
    Engine : 2.2
    I put 40psi in mine, been doing that for years on different cars that I've run 18,s on. Reason is you normally lose a couple of psi in the first week or so due to air temp (You lose pressure quicker in the summer)
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    Putting 40 in mine as well.
  1. Correct tyre size on 18's?
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 8th July 2012, 16:13
  2. Right tyre size for 18's?
    By unikarl in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 11:43
  3. tyre presure??
    By byers in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 22:01
  4. Tyre presure question
    By domjfan in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 17:35
  5. 18's - What tyre size? Offset?
    By aaruck in forum Styling
    Last Post: 10th October 2007, 12:31
