Thread: Auto gearbox ECU reset
    Essex
    Default Auto gearbox ECU reset
    My wife has a 2006 1.9 CDTI with an auto box and I was wondering if it is possible to reset the learning on the gearbox?
    It seems to hold on to the gears for far too long requiring a manual change in +/- mode. Is this possible and if so, how?
    Thanks all.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    What's her driving style like, the harder you depress loud pedal, the faster it will change up. If you are very light footed it will take noticeably longer.
    Aug 2011
    Northfield, Birmingham
    maybe give it an gearbox oil change, that oil has most likely never been changed... may make the world of difference.. or maybe the gearbox oil temp sensor inside the box maybe faulty.. delaying the gear change, and diesels tend to be laggier through gear changes in comparison to the petrol version..
    Essex
    Although it's her car, I do all of the long distance driving and I drive like a jessie It just ****es me off that the more sedately you drive the more the car screams its' nuts off.
    Full Member
    Bristol
    The gearbox is designed for economy. if it get to high gears to soon and you labour he car it uses more fuel. The box will only chang up when it get to the correct speed to change. If your are going downhill and take your foot of the pedal it still will not change up unless you are at the correct speed. If you use the sport button to get going it will change up faster. Then take it out of sport mode and away you go.
    WGAF#5
    And to answer your question - disconnect the battery for 10 minutes ( make sure you know how to reset the windows and have the radio code if needed)
    When you reconnect the battery the average milage and the trip should have returned to zero and the gearbox ecu will also have reset too
    Full Member
    Bristol
    I rest all the ecu's on my mates Z3.0CDTI auto and it made no difference at all. Even took it to an auto gearbox specialist an he said box was ok. The battery was disconnected for 3 days that did not change anything.
    Essex
    Thanks all. I will have a go and probably end up having to put up with it if I can't reset to a default mapping.
    On the plus side I replaced the drop links last night and I have got rid of the front end know
  1. auto gearbox
    By Paddy in forum Engine & Drivetrain
    Last Post: 26th March 2011, 22:40
  2. F23 auto gearbox oil
    Last Post: 12th March 2011, 21:56
  3. auto gearbox?
    By no1golfer in forum Engine & Drivetrain
    Last Post: 24th July 2009, 22:09
  4. auto gearbox
    By cerbrious in forum Engine & Drivetrain
    Last Post: 17th July 2009, 20:04
vectra automatic gearbox problem reset
ecu locations on vectra c 1.9cdti auto
vectra c ecu resetwhere is the automatic gearbox ecu on a vauxhall astra g tovectra c auto box sportreset automatic gearbox ecu problemsdownhill control With automatic gearbox on vectra chow to reset gearbox ecu vauxhall vectra 1.9 semi auto faultvectra c automatic gearbox problemsvectra c gearbox ecugearbox ecu remap vectra cvectra c auto gearbox settingsvauxhall corsa automatic gearbox resettingvectra c automatic ecu resetvauxhall vectra automatic gearbox faultsvauxhall corsa automatic gearbox problemsopel signum automatic transmission problemsvauxhall astra h automatic gearbox ECU faultopel vectra b automatic resetopel vectra b automatic how to resetopel vectra b transmission ecu how to resetwhere is a Vectra auto Gearbox ECUhow to clear vectra c automatic transmission learningvectra c reset automatic gearbox
