Thread: Vxr dials mod...?
    Apr 2011
    Brough
    Default Vxr dials mod...?
    A specific vxR feature...
    http://www.youtube.com/watch?v=Tr59-...e_gdata_player
    Anyone ever got ahold of a set of Vxr dials and replaced their originals to do this? Or is there existing hardware already installed requiring only software updates or tampering to enable this feature?
    If so would it work in my v6 Turbo?
    I believe they work in any Vectra, but obviously it has to be a petrol for the rev counter to work properly...
    Apr 2011
    Brough
    Like a plug and play job?
    WGAF#5
    cant watch the video via works pc... is it the needle sweep that you specifically want ??
    (summising thats the vxr dials feature)
    if so theres a plug in device called happylightshow that does the needle sweep and so much more ...
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    where would you get this happy lightshow device fella
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    http://www.happylightshow.de/
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Quote Originally Posted by Ian-Highlander View Post
    yep, mine does the needle sweep - i've got the happylightshow module - a little expensive at 100 euros, but it does a whole lot more then the needle sweep.
    Apr 2011
    Brough
    Quote Originally Posted by peelmeister View Post
    What features can I expect with this bad boy?
    WGAF#5
    Quote Originally Posted by devster24 View Post
    if you click on the link Ian so kindly posted
    All is explained ..
    SPEED LOCK
    The car will be closed when faster then 15km/h
    possible options: on / off
    OPC SCAN
    The tachometer pointers run till maximum and back (not the fuel pointer)
    "LEAVING HOME" + "COMING HOME"
    Lock and unlock the car will activate front and back lights
    possible options front lights:
    - off
    - park lights + fog lights
    - turn lights + repeater + fog lights
    - highbeam + park lights + fog lights
    - just park lights
    possible options back lights:
    - off
    - reverse lights + plate lights
    - turn lights + plate lights
    - brake lights
    - reverse lights + 3. brake light
    - turn light + reverse light
    time of shine:
    10sec / 25sec / 45sec / 55sec
    Cornering Lights + Daytime Running Lights
    If Lightswitch is set to Low Beam, then the foglamp get activated.
    If turnswitch is pressed and vehicle speed slower than 40km/h cornering lights get activated.
    If Lightswitch is set to “0“ (off), then the foglamp gets activated when engine is turned on.
    HAPPYLIGHTSHOW
    You can activate different light-shows
    (the outer lights shine alternately)
    Activation:
    The Happylightshow is very easy to install, because it's only being put on the diagnostic link connector (DLC)! Please download the "setup procedure description" and the "mounting guidelines description" as *.pdf file under "description". To download the right file, you have to take a look on the back side of your Happylightshow. You find there a number with your Software Version.
  1. 2.2 dti dials
    By MattHD in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 07:09
  2. SMD dials????
    By Rab in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2010, 12:45
  3. Dials
    By WiCkEdOnAmIsSiOn in forum Styling
    Last Post: 15th May 2006, 01:09
