Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Autolights
    Regular Member R2XPT's Avatar
    Scotland
    Question Autolights
    Hi I have the auto xenon light switch, roof loom, preface window sensor so I will need to get the facelift sensor and fit it all and get it tech2'd
    Is there anything else I need to get/do to get the autolights/rain sensor to work before tech2?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    New windscreen...
    the roofloom is that for facelift? im sure the wiring is not the same.. (not sure if they go to the same place in the REC)
    Scotland
    Was the replacement screen I got fitted started this as it had the space for the sensor that was there....
    So are the roof looms diff on preface and facelift? Seller didn't state which it was for but when I saw the code on the sensor it's different to facelift, does that matter?
    Engine : 2.2 Direct
    The difference is in the plug.. if your current connector for the rainsenso fits the "preface" sensor (that is wider than on the facelift)
    Scotland
    Ok cheers, as for the autolights does that work thru the rainsensor loom?
    Engine : 2.2 Direct
    yes.. theres a sensor on the facelift rainsensor (the middelpart) that is not present on the prefacelift sensor.
    Scotland
    Thanks just need to find the loom and sensor, u think it's worth while me having a peek to see if I have the plug already there behind the interior lights as my car seems to have most looms already there from mods I've fitted?
    Engine : 2.2 Direct
    It takes 10 seconds to check down with the alarmsensor then it should be there if you have it.
    Scotland
    Thanks does that part just pop out?
    Engine : 2.2 Direct
    yes .. take a grip closest to the windscreen.
  1. retrofit autolights and wipers
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2013, 19:18
  2. Autolights?
    By lukesignum in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2010, 22:40
