Thread: fog light not working
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Default fog light not working
    hi there has anyone got an idea why my front fog light isnt working? i have changed the bulb but still nothing
    6 Post(s)
    Unplug the multiconnector plug from the fog light and see if the contacts are wet and corroded.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    also check the plugs that go into the fogs themselves as mine were full of water
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    there was water in there a few days ago so i left the cap of and vented it. there is no water now. any ideas? could it be a fuse if so which 1 it dosnt say in the manual
    6 Post(s)
    If the other fog light is working then the fuse is ok.
    The water may have dried out, but have you checked the contacts and tried cleaning them if dirty / corroded?
    Aug 2011
    Berkshire
    Is it an exclusive? If so only the R/H side one will be working. Pul off the L/H connector to the light and see if there is a wire missing? I have recently discovered this as advised by someone on here. Advised to run a wire from the other side after fitting a pin in the connector. (Available from Maplin apparently.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Quote Originally Posted by frogger View Post
    your referring to the rear fogs mate, the OP has an issue with his front fog
    6 Post(s)
    Is it an exclusive? If so only the R/H side one will be working..
    Quote Originally Posted by Caveman_nige View Post
    All Vectra-C's by default only have one working rear fog light. It's not just something that the Exclusive trim spec has over other trim spec models.
    But as said, the OP is asking about the front fogs, not the rear one.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    front left hand fog light if sitting in the car. noticed a bit of rust on the connector and cant get the wire out. hopfully thats what it is. if not any ideas
    6 Post(s)
    The LH one (nearside in other words) is renound for always being wet.
  1. interior light not working
    By chubby in forum Troubleshooting
    Last Post: 2nd September 2013, 20:26
  2. rear fog light not working
    By keggy77 in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 16:59
  3. Interior light not working
    By Jock-W in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2012, 21:21
  4. 1 HID Light not working
    By MoonPig in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2011, 20:54
  5. Is it right to only have one rear fog light working ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2006, 15:55
vauxhall vectra c front left fog light not working
