Thread: Cd30 mp3
    Regular Member GoldenWonder's Avatar
    Durham
    Default Cd30 mp3
    Quick question, my 2006 Vec had the CD30 in it (with a code), if I get a CD30 MP3 from ebay do I just need the code, or does it need programming in at a dealers as well?
    If so, whats the point of the code?!
    Full Member
    South West
    The headunit and the screen are whats known as "married" ie they both require the same code in order to work.
    If you buy only the CD30 MP3 from ebay, it will either have to be Tech2 Cleared so it can be re programmed to your existing screen via Tech2, or if it has not been cleared, you will need the current code for the CD30 MP3 so it can be coded into your car.
    The best option for you would be to buy a CD30 MP3 and screen as a pair. As long as the screen and headunit are removed from the same vehicle, it will fit straight into yours without the need for any programming.
    Hope this helps
    Durham
    Thanks for that - does that mean the 'new' CD30 would work in my car but just wouldn't work with the screen?
    Might see if I can get the screen on ebay as well - cheaper than visiting a dealer and have them take my eyes out for a 2 minute job.
    Full Member RBH's Avatar
    Jan 2008
    North Lanarkshire
    86 Post(s)
    Vehicle : VECTRA
    Trim : SRI XP NAVI
    Engine : VVT
    Mileage : 73,166
    wud the cd30 mp3 and screen from an astra h fit the vectra c?
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  3. Cd30 & bid
    By KyleSxi in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 15:50
  4. CD30 to CD30 MP3 Conversion
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 00:20
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
astra h cd30 mp3 fit a vectra c
vectra c cd30 mp3
