Results 1 to 10 of 18
Thread: Engine Overheat/Blocked pipes?
    Regular Member toaffer's Avatar
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Engine : 1.8 VVT (Z18XER)
    Mileage : 73K
    Default Engine Overheat/Blocked pipes?
    Any input appreciated!!! just purchased car today and done less than 30 miles when noticed yellow engine light on (engine symbol with water) and car stayed just above 90 celcius,water level was rising up and down in the reservoir and then drained from reservoir completely so topped up with water again and still the same,tried squeezing pipes leading to and from radiator etc in case of air bubbles but still same problem< Engine seemed to get noiser (tappy) also...any ideas guys? Cars going straight back to dealers tomorrow but just wanted the heads up first,cheers,nervous Toaffer!
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Sounds serious whatever the outcome is.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    If it's pressuring then going could be headgasket mate
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Quote Originally Posted by CritchvxD View Post
    O deary me! well I'll get onto the dealer first thing 2moz,thank god for 2 month warranty!
    Glasgow
    Water pump or head gasket failure.
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Quote Originally Posted by byebyeitsagsi View Post
    Jeezo! cars done 36K and ex mobility!
    Regular Member paddyvectra's Avatar
    Jul 2011
    Carterton, but.....I walk a lonely road the only road i have ever known
    Sounds mad but check that all your fans are still intact. I had a 306 where the rad fan had been removed when i was driving it was ok as it was being cooled by the cold air hitting the front of the car. However when i stopped in holland on way back from germany to feed the lil one i left the engine running and the thermometer shot right round a STOP light come on couldnt figure it out. Let it kool and was fine this happened every time the car was idling it was over heating itself got a mate to look at it then the missus informed me her german mechanic had removed the fan as it was 'clunking' and never replaced it but she had decided not to inform me!!!!
    Dunno if vectra's run off a similar fan system but maybe one to check pal
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Quote Originally Posted by paddyvectra View Post
    Will Do although light so far only came on when driving the car basically round the block and back didnt come on on idle!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I would guess either.
    Head gaskets can go at any time, as I found out on a brand new (02 reg) Fiat Seicento, with 120 miles on the clock.
    With the engine ticking over, can you see water coming back into the header tank from the top (small) hose? If not, It could just be the water pump.
    hth
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Quote Originally Posted by tony-1977 View Post
    hth
    Yes mate water is coming back in to tank
  1. CDTI 150 - Engine Pipes Sizes?
    By Leemarksmith in forum Diesel Engine related
    Last Post: 21st February 2013, 18:23
  2. brake pipes - engine subframe rear mounting
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 09:18
  3. blocked cat on a 2.0t
    By tomo41 in forum Engine & Drivetrain
    Last Post: 12th June 2011, 22:50
  4. Wonder if this guy blocked his egr!
    By John LE in forum The 'Off Topic' room
    Last Post: 21st June 2010, 09:09
  5. Engine pipes
    By thegoldenbullet in forum Styling
    Last Post: 19th September 2007, 14:52
