Thread: Retro fit factory HIDs inc headlights
    Engine : 1.9 CDTi
    Default Retro fit factory HIDs inc headlights
    Is it possible to retro fit the hid headlights to a preface Vectra/Signum?
    If it is possible do they just self level or do they turn (AFL) when you turn the steering wheel too?
    It is possible to fit both the standard xenons AND the Adaptive Forward Lighting setups. The standard xenon is easier, for obvious reasons, but they won't self-level automatically. A few people have done it on here, and it's not too difficult - you just need a level sensor and a lot of tech2.
    The AFL setup is a bit trickier as there are lots of extra components including level sensors, a new CIM specific to the AFL with a different steering angle sensor, and a LOT of Tech2. Andy.l has done it, and if you search through his threads you'll find the one where he retrofitted it to his car.
    The biggest issue you'll have is finding the headlights, especially the AFL ones, as they're quite rare and were only a factory option - they weren't standard on any model except the very early GSI's. Even then it was just the normal Xenon.
    Like all things, however, it IS possible...
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    lee if there the ones from vectra man let me know as I know him, could see if I can get a deal for ya mate
    Engine : 1.9 CDTi
    Who's Vectra man lol
    Penfold I am not to worried about AFL but would like self levelling hid headlights.
    Any more info on how to do it?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Ive put in OEM xenon headlights to my vectra.. but i do not use the selfleveling via the sensors.
    I use the selfleveling via the shocks (OEM part from VX)
    the easy bit is to get them to work.. (just add a ground wire, and enable xenon in the UEC)..
    The tricky part is to get the leveling if you want that via sensors.
    Engine : 1.9 CDTi
    Yeah I want the leveling.
    I have aftermarket HID's with Xenon's enabled already
    Engine : 2.2 Direct
    You will need besides the headlamps:
    front and rear axelsensors
    AHL module
    Lightswitch for Xenon
    level motors for xenon
    Wiring.. (probaly easier to make up, than change everything in the car...)
    Engine : 1.9 CDTi
    Sounds expensive lol
    Engine : 2.2 Direct
    Probaly not cheap
    WGAF#5
    Also remember that factory/retrofit xenons/Hids require a washer system to be fitted that operates on every 4-5 cycles of the windscreen washers too
    Hella did a preface conversion kit a few years ago including the wiring self levelling sensors and the correct factory headlights and washer system
    Don't know if they still show the link anywhere...
  1. Retro fit automatic headlights?
    By Welsh_J_2000 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2012, 20:09
  2. retro fit auto headlights
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2011, 12:55
  3. Can Xenon headlights be retro fitted?????
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2011, 23:13
  4. CD70 Factory Sat Nav- Retro Fit possible?
    By vec1975 in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2008, 17:59
  5. Retro fitting Xenon headlights - what's needed?
    By Duncan in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2007, 11:10
retro fit xenon headlights to vectra c preface
