Thread: 2.2 DTI intermitent problem..
    Sep 2010
    northants
    Default 2.2 DTI intermitent problem..
    Hi guys, long time no see!
    Ok my vectra has started playing, but only sometime!
    Seems to do it when i travel long journeys, or do a lot of stop start driving, like going to the shops, back home, to the dentist, to the garage etc etc. Also noticed it doing it if you get into a high gear as coming up a slip road, then try to accelerate itll happen.
    Ok, drives absolutly fine 90% of the time, but sometimes itll go into limp mode while driving, wont rev above 2200rpm, if your driving it at the time will not accelerate, like theres no turbo, BUT if you stop, turn it off and restart the car itll have cleared!
    Had it scanned and had a code like a leak somewhere, so checked all the solinoids and all the rubber connectors from the actuator to the inlet and found one split connecting to the actuctor looking thing on the egr, so replaced that and thought happy days, but then it struck again!!1
    Anybody had this problem?
    Regular Member Innes's Avatar
    Plymouth
    We need to know the code really.
    It could be this but without code it's guess work!
    Sep 2010
    northants
    Who!! glade you sorted yours out bud!!
    im just waiting to here back from the mechanic who looked at mine which fault code i had, but rading your problems i does sound like the same thing....under load in top etc etc
    Sep 2010
    northants
    ok code is - P0234 - boost control incorrect flow
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by peteh View Post
    Have you cleaned the boost sensor?
    Sep 2010
    northants
    ermm no! lol
    which one is it? one near the front, near the rads?
    Plymouth
    Heres a pic with the usual suspects highlighted.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I cleaned the boost sensor on mine (identical engine), had no codes or limp mode, but it still made a huge difference to performance
    Sep 2010
    northants
    cheers lads for the heads up and pics, really don't know what to do at the mo, just get rid how it is or try and fix it and get more £...
    cause of this stupid new law ive had to SORN it now, so can't even use it for a week to test it, grrrr
    think it's worth £1500? only done 89k fsh and not long been mot'd
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Takes literally a minute to get the boost sensor out mate, give it a good clean with some carb cleaner and a light thin brush if it looks really dirty. Got to be worth a try!
  1. Intermitent Problem
    By Alphonsethegreat in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 18:05
  2. Intermitent low down power loss
    By bert3d in forum Engine & Drivetrain
    Last Post: 13th January 2012, 18:18
  3. intermitent tickover problem
    By Arnie1 in forum Engine & Drivetrain
    Last Post: 16th November 2010, 17:37
  4. intermitent dash failure
    By pfloyd in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2009, 09:30
  5. speakers intermitent
    By surreyl31 in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2007, 21:26
