Results 1 to 10 of 19
Thread: Hid problem
    Full Member RBH's Avatar
    Jan 2008
    North Lanarkshire
    88 Post(s)
    Vehicle : INSIGNIA
    Trim : VX LINE
    Engine : 2.0 CDTI
    Mileage : 44000
    Default Hid problem
    just fitted my hid kit from HIDS DIRECT into my fog lights
    these ones
    http://www.ebay.co.uk/itm/2206727304...84.m1439.l2649
    obc says fog lamp error and the lights are flickering.
    not happy with this as the HIDS DIRECT kit i bought for my main beam are perfect.
    anyone shed some "light" as to why this is happening to the kit ive just bought??
    cheers
    rab................
    stockport
    Arrow
    Quote Originally Posted by RBH View Post
    these ones
    cheers
    rab................
    You might find that you have to fit cancelers to them to eliminate the flicker etc,etc. FELIXX.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    The foglights are part of the bulb check system so they are reading a lower resistance than normal halogen ones hence the errors. Did they come with cancellers?
    Jan 2008
    North Lanarkshire
    88 Post(s)
    Vehicle : INSIGNIA
    Trim : VX LINE
    Engine : 2.0 CDTI
    Mileage : 44000
    that the wee box between the bulbs and the ballasts?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yes should be.
    Sep 2010
    it does say Canbus compatible on the box so maybe the wrong product has been provided?
    Jan 2008
    North Lanarkshire
    88 Post(s)
    Vehicle : INSIGNIA
    Trim : VX LINE
    Engine : 2.0 CDTI
    Mileage : 44000
    just had this back from email i sent.....................
    Hi there, I'm sorry to hear for your problem. Unfortunately, these kits as good as they are when working only work with 99% of cars so they can cause errors in some. That said, the Vectra C is normally fine, however, you will need a set of HID warning cancellers to sort the problem out. We will send you a set free of charge so you can get this problem sorted. If for some reason it doesn't fix it then you will need to send the kit back for an exchange for another or a refund. I'm pretty confident that it will work as we supply alot of these kits for the Vec C, in fact we've supplied 1000's with normally no problems at all.
    I will get the parts sent to you tomorrow if there's any further issue please get in touch and we will refund you or try something else.
    Martin Fance
    - hids-direct
    Regular Member bigdave1701's Avatar
    York
    Sounds like pretty good customer service.
    Regular Member R2XPT's Avatar
    Scotland
    Rab are they H11's for the fog bulbs?
    Jan 2008
    North Lanarkshire
    88 Post(s)
    Vehicle : INSIGNIA
    Trim : VX LINE
    Engine : 2.0 CDTI
    Mileage : 44000
    Quote Originally Posted by bigdave1701 View Post
    it certainly is, coz i foned direct to manchester and it said they closed at 4pm......so i was surprised to see this message in my ebay message box
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
