Thread: AUX in on CD70 programing
    Engine : 1.9 CDTi
    Default AUX in on CD70 programing
    If you retro fit Aux in on a CD70 what needs to be programed and can it only be done with Tech2?
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Hmm, there are a few threads on this..
    I understand, that the code index needs to be changed to something like 013
    This should allow the head-unit to display the Aux-In Folder
    Tech 2 is the most reliable method of achievng this although I know that Op-Com and Vaux-Com are able to do simple Code Index, Variance Config changes to suit.
    It is also recommended that you get the firmware update disk for late 2007 onward.
    so not 04/04/2007 or earlier.
    Look at Yysnet's how 2, as I am sure he goes into both the elctronic and programming changes required.
    Engine : 1.9 CDTi
    Thanks for the info
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Plasma did mine with his tech2 when he had it..
  1. new egr fittment does this need programing in to ecu
    By murf2484 in forum Engine & Drivetrain
    Last Post: 28th September 2012, 20:34
  2. Key Fob programing?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2012, 10:24
  3. key programing question
    By iansfocus in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 14:46
  4. key programing
    By johnturbo in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2009, 10:53
  5. sky remote programing?
    By adfrodsham in forum General Chat
    Last Post: 10th May 2009, 16:50
