Thread: 2.2 direct using oil
    Regular Member trickyjacks.4's Avatar
    nottingham
    Default 2.2 direct using oil
    I wonder if anyone can shed some light on a problem I've got, I have my oil and filter changed every 10,000 miles and noticed on a recent check that the oil level was low so I topped it up,I then went on a trip up north last weekend and halfway there the low oil level indicator came on.I've not got any leaks and when stationary can sometimes smell oil.
    its got 102,000 onthe clock.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    mine uses oil if I use full synthetic but not if I use semi dont know why
    Full Member Big Sig's Avatar
    Vauxhall say normal usage can be up to 1000ml per 1000 miles. Seems a lot I know but thats that they say is acceptable.
    A lot of cars don't use any, but some do, just the way it is. maybe next time try some 10w40 or 5w40 as its a bit thicker so doesn't seep past the seals etc the same. Just note, if you do use those oils then stick to 10k oil changes.
    nottingham
    thanks for the replies fellas maybe it's normal then but would that explain the smell?
    The smell could be from a small leak or even a breather hose that's split.
  1. I think my 2.2 direct has too much oil in it....
    By Knuckle in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2011, 15:18
  2. vectra 2.2 direct/non direct
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2009, 00:05
  3. 2.2 Direct mpg normally this bad?
    By Marc C in forum Engine & Drivetrain
    Last Post: 9th August 2008, 12:46
  4. 2.2 Direct 16v
    By cdms811 in forum Petrol Engine related
    Last Post: 12th December 2007, 00:55
  5. 2.2 Direct
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 20:50
my 2006 vectra c 2.2 direct is using alot of oil
