Thread: 1.9cdti 16v fuel pump
    Feb 2011
    n wales
    Default 1.9cdti 16v fuel pump
    Hello all. i recently had my inlet manifold replaced due to the swirl valves going and the egr valve fault. Today i noticed a strong smell of diesel. I have just had a look and on the left side of the engine under the fuel pump there is a pool of diesel. I have read that the fuel pumps can leak on these engines. Is this an easy job to replace the fuel pump? Any help would be much appreciated. Thanks
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    The fuel pump on this engine can cost at least £2,000. Where is the pool exactly?
    I think they can be refurbed though.
    Insignia VX-Line Nav CDTI 170.
    Feb 2011
    n wales
    THanks for your reply. From where I can see it's directly under the fuel pump and the pump itself looks wet. Is it a relatable easy job to replace or is it a garage job? Thanks Paul
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by paulcdti150 View Post
    Think garage job. Is the fluid/fuel ontop of the manifold?
    Feb 2011
    n wales
    Yes it is. The manifold has not long been replaced so it's very clean so you can see it easily. Going to have a proper look tomorrow and see if I can see anything. I'll post my findings. Thanks Paul
    Full Member Penfold101's Avatar
    To replace the pump is a peice of cake - it has to come out to replace the manifold anyway. It's driven by the cambelt but you can lock the sprocket in place and it isn't timed so it wouldn't take more than a couple of hours to change at most. I don't know how much they cost but if it's only been leaking since the job was done it could simply be a loose pipe or hose...
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    ****** I have that.
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Quote Originally Posted by Penfold101 View Post
    Yeah I read somewhere that the metal pipe from the pump to the fuel rail should be replaced once the unions have been undone. I re-used mine when I replaced the manifold but I was very careful the fittings didn't get cross-threaded and did them up ****ing tight! There was a post from one member who had leaking fuel after a manifold change and he had to use ptfe tape on that pipe fitting to cure it.
    Feb 2011
    n wales
    Hello all. Thanks for your replies. After a better look today in daylight i spotted the problem straight away. On the fuel pump if you look straight at it there is a large torx bolt and 4 smaller ones around it. One of the smaller ones had come out so the fuel was leaking out of there. I phoned the stealers who said they dont do any spares for the pump only complete pumps priced at £1064plus vat!!!!. So i took one of the bolts out and took it to a local faster place who matched it exactly size wise but with an allen head instead of a torx and he give them to me for free!! Bonus. Put it on tightened it up and its not leaking any more. I will take some pics and post them as they may be help to somebody in the future. Thanks Paul
    Hertfordshire
    Excellent result! Bet you're well happy with that
  1. 1.9cdti fuel pump leak
    By Ninj in forum Engine & Drivetrain
    Last Post: 20th July 2012, 21:17
  2. help fuel pump on 1.9cdti 150
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 30th January 2012, 13:34
  3. Fuel pump gear 1.9CDTI
    By jpimpao01 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 19:18
  4. Fuel pump 1.9cdti 150
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:42
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
vectra 1.9 cdti fuel pump problems
https:www.vectra-c.comforumshowthread.php147101-1-9cdti-16v-fuel-pump
vectra c cdti oil pump problems
fuel pump sensor vectra c
insignia cdti remove fuel pump
vectra c diesel pump removal
leaking fuel pump on vectra
1.9cdti fuel leak issue
removing vectra c 1.9 fuel pump
1.9cdti vauxhall fuel pump location
vectra c cdti diesel pump
fuel pump tank replace vectra 1.9 diesel
how to replace zafira 1.9 fuel pump
diesel pump vectra c 2007
1.9 cdti fuel pump test
opel vectra 1.9 cdti fuel system
astra cdti fuel pump removal
astra 1.9 cdti diesel pump leaking
vauxhall vector 1.9fuel rail removal steps
vauxhall vector 1.9fuel injector rail removal steps
insignia fuel pump leaking
vectra cdti oil leak left side
vectra c fuel pump on engine
vectra c 1.9 cdti fuel pump
optic sensor fuel pump 1.9cdti
