Thread: Might be a simple question.
    Mar 2011
    South Normanton, Debryshire
    Default Might be a simple question.
    If my New MAF sensor wasn't working right would that throw up the code P0100 for voltage problems or would it not work all together as soon as i start the car up and go into limp mode as at the moment it works for a while then drops into limp mode?
    Might try in the morning by putting my old Bosch one back on seeing as it just had a split pipe before which would of been making the car go into limp mode before i brought the new sensor.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It probably would mate as they work on voltage.
    As the air flow travelling through will increase current and therefore change voltage.
    Maybe try cleaning it with some electrical contact cleaner.
    Engine : 1.9 CDTi
    Causes
    A code P0100 may mean that one or more of the following has happened:
    • The MAF may be disconnected, or a wiring connection may be bad
    • The MAF sensor may be faulty
    Possible Solutions
    The simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures:
    • Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires.
    • Unplug and reconnect the MAF wiring harness
    • Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information)
    • Replace the MAF sensor
    Mar 2011
    I'll Have a look at that then tomoz might even try cleaning them both see what happens don't think it can make it any worse lol
    All you do is just spray it inside don't you?
    Mar 2011
    Surpose another way is to find someone near me that knows there MAF works and ask if theyll swap it into mine to try it but i don't know anyone round my way with the same car lol
  1. 1.8 vvt simple changes for better MPG?
    By Chip in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2012, 16:31
  2. Simple Question..
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 10:21
  3. simple question ??
    By llcoolr in forum Engine & Drivetrain
    Last Post: 14th December 2009, 17:14
  4. Simple 1.9CDTi Oil Leak Question from Mechanical Muppet
    By SandyGBR in forum Engine & Drivetrain
    Last Post: 14th August 2009, 10:21
