Thread: What to polish my newly sprayed plastics with?
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default What to polish my newly sprayed plastics with?
    Just sprayed the plastic trim that goes from by my steering wheel right to passenger door on the dashboard.
    After taking it off, rubbing it down, priming it, painting it, laquering it, I must have re-done it about 3 times, first because of a drip, second because of bits in the laquer, and 3rd because paint had cracked off around were I masked off that little design strip!
    Anyway managed to drill out the melted plastic tabs that hold that strip in and have decided to rub it down and re spray it again!
    Just done my final clear coat, what do I use to polish it up? Can I use T-cut lightly or will it dull it?
    Also, how do I remove the ashtray lid and the 12v socket surround and cap to paint that also, seems the little compartment above it is in the way but I can't get that out
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    Ash tray lid is delicate or you break the clips. You need a fine screwdriver. prise the clips off and slip the screw driver under to stop them reclipping back. takes about 5 mins to do.
    The compartment comes out with a bit of force, I have Cig lighter so makes it easier, but i guess if you have the cap, pull the tray out a bit then angle up and remove. The cig lighter surround then just unclips. hope this helps
    Regular Member A1-9 SRI's Avatar
    CHESTER
    john, you going the meet later. will show you then bud if you do
    Mar 2011
    Wirral
    Got them out now, used a couple of flat bladed screwdrivers to get the compartment out then just tugged the ashtray, don't think I broke anything lol!
    I hope so, car went in the garage this morning for cambelt, waterpump, alternator belt, brakes, CV joint and I asked them to have a good look at it as MOT is in november.
    They rang me before, turns out I have a front spring snapped and several bulbs out also so they are replacing both front springs now too. Asked him if it will still be done today and he said hopefully if not tomorrow mid morning.
    He is phoning me this afternoon to give me an update so guess I will find out then.
  1. My Newly smoothed Vectra C
    By Cossy in forum Quick Photo Album
    Last Post: 25th February 2013, 14:57
  2. Pics of my newly fitted VXR diffuser
    By SillyMoose in forum Quick Photo Album
    Last Post: 27th June 2011, 09:22
  3. Newly fitted suspension looks very high..will it drop??
    By marky2027 in forum Suspension, Wheels & Brakes
    Last Post: 24th July 2009, 15:51
  4. newly shaped signum with air vents
    By butcher-boy in forum General Chat
    Last Post: 8th June 2007, 19:06
