Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: K&N Panel Filter
    spoons
    Guest
    Default K&N Panel Filter
    Hi all,
    Where is the best place for me to get a K&N Panel Filter for my Facelift Vectra 1.9 CDTI (195bhp VXRPC Remap)
    I've been quoted between £52-£59
    ...and is this the correct part code K/N Panel Filter 33-2848
    as seen in the 'How to Guide' Here
    Here, there and every where!
    That part number is correct Steve, i've just checked the side of the box
    Just checked the website and it gives you a load of local dealers m8. LINK
    Regular Member Harry's Avatar
    Uxbridge, London
    tut...tut, you should've done this before the remap steve. i doubt it'll make much difference, but the map has done taking into consideration the factory air flow rate.
    unless you are just replacing the existing k&n you've got in there
    There is a seller on E-bay, LINKY
    spoons
    Guest
    Quote Originally Posted by Harry
    tut...tut, you should've done this before the remap steve. i doubt it'll make much difference, but the map has done taking into consideration the factory air flow rate.....
    How would they know anyway, he didnt even lift the bonnet !!, do I have to tell them that first ??? (blind leading the blind springs to mind)
    Anyway, just wondered if we have any approved K&N traders so I can get a cheap price cos I always end up paying top whack, turn up to a club meet, then someone says "jeeze, you paid HOW MUCH"
    Oct 2006
    ESSEX
    Default K & N filter
    watch out for potential MAF problems after fitting a K & N
    coming from a world of VAG cars (seat, and golf were previous cars of mine) - there has been quite a few articles about potential contamination of the MAF sensor with oil mist from K & N filters (and other 'performance' filters)
    alot of people seem to be leaning back towards using the standard OEM filters, as these dont give the same MAF problems - also the airflow benefits on K&N type filters are often so small that the benefits are greatly reduced
    just my experience
    regards - TB
    My K&N has been in for over 12 months without any problems at all
    Uxbridge, London
    Quote Originally Posted by spoons
    How would they know anyway, he didnt even lift the bonnet!!
    they didn't lift the bonnet to remap the ECU?
    Regular Member bobbyboy's Avatar
    Jan 2006
    Durham...
    I got my filter from WWW.potn.com ......cost about £42.00 delivered that was in feb though......good luck...
    Dec 2005
    In the sponge-monkey tent
    Not if they do it through the OBD port under the ashtray...
  1. For Sale: K & N Panel Filter
    By peelmeister in forum Parts for sale
    Last Post: 8th June 2011, 21:22
  2. Standard air filter or K&N Panel Filter
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 15:38
  3. K&N Panel filter
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 16:05
  4. K&N panel filter
    By Dwabo in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 2nd March 2008, 22:56
  5. K&N Panel Filter
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2006, 19:56
