Does anybody have a problem with HID's bulbs on the off side, Ive changed 3 bulbs within 6 months, last bulb changed on Friday and its blown already...grrrrrr..... Got bulbs from hids direct 35w 6K.
replace the ballast?.
You sure they are blown? Sometimes my nearside one goes out, I just turn them off and turn them back on again, and its cleared and working again.
swap them over then if the nearside goes again, you have a problem....
check the voltages on both sides...but on saying that, most ballast will run from 9-18 volts...
but the voltage should be equal either side give or take a volt.
only had trouble with ballast in a bad location, not enough air moving round it (they condensate and get damp). Once I re-located them mine are fine .. 35W 6000K
Mine were fitted within the wings which clearly didn't get the required breeze - didn't like the area under the headlights so mounded mine on the front crash member
weird cos there sealed with resin?
