Thread: New battery
    Sep 2009
    Glasgow
    Default New battery
    Hi as posted before have had a new alternator and battery fitted last tuesday, chaecked today using volt meter and battery checker and it's showing the battery to be of low charge on the battery checker ? it lights up the amber light for 12 v but not the green at 12.5 v how long does a battery need to bed in.
    Regular Member poves's Avatar
    lancashire
    I'd imagine at 12v amber , the battery is holding charge , as long as when it's running the alternator is pumping it with between 13v-14v it should be sweet.
    Aug 2010
    Leeds
    When it's been run for 30 mins or more check the battery at idle with your volt meter.
    Charging wants to be 13.4-14.1 vdc within that range is ok with all lights off and other electrics.
    Then switch off and take a reading it will drop to around 12.4 to 12.7 for a fully charged battery.
    When the doors have been locked the battery may increase in voltage after 20 mins approx due to the can bus wiring shutting down.
    What readings have you got and how much good running have you done? or is it local stuff which weakens batteries if not fully charged.
    Sep 2009
    Glasgow
    did a good bit of milage today and battery now reading fully charged thanks for info
    Aug 2010
    Leeds
    It may have been on the shelf since the last winter and required a charge, we used to charge our stock of batteries every 2 months or so we was supposed to.
    It will be fine now if at full charge and when winter comes it's best to start with your clutch in to take stress off the engine to make it easier to fire up, i do this all the time it's just habbit.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Key fob battery
    By Fausty in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2011, 02:38
  3. Battery
    By Wolfie01 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 23:52
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
