Thread: update on current speedo problem
    Regular Member farley2708's Avatar
    antrim n.ireland
    Default update on current speedo problem
    hi,replaced the SMD's all went ok,problem is the speedo,got a sat nav,speedo reads near enough what the sat nav reads (give or take 3mph)
    my problem happens when i switch the car off,the needle falls down into the info window (see pic)
    can anybody help?
    Birmingham
    I had an issue with a temp needle on Astra-G some time ago, I knocked it out of place when I was putting chrome rings on, that too didnt read properly.
    Someone on another forum said to do this.....
    Take needle off, put the cars ignition on, wait until all needles settle to correct place, place needle back on where it should actually be, turn ignition off.....and it should be good.
    As said, it did the trick on the Astra-G.
    Try at your own risk though.
    Good luck.
    Bye bye Vec B
    - Hello Siggy!
    antrim n.ireland
    so my thanks to 'Vaux-Man-G' for the cure to my speedo needle problem,took it for a drive with the sat nav to compare speeds,30,40,50,60,70 up to 85 only out by 3-4mph less than what the sat nav displayed,so happy now
    before
    after
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    Woop Woop the site proves its worthy again. Glad you got it sorted Nigel
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    WGAF#5
    Well done mate... You got there in the end
    Well within the tolerances of a "normal" car
    Birmingham
    Quote Originally Posted by farley2708 View Post
    Glad to be of help mate, even more glad you sorted the problem, its a frustrating issue.....
    Bye bye Vec B
    - Hello Siggy!
  1. problem with speedo needle
    By farley2708 in forum Bodywork & Interior
    Last Post: 12th September 2011, 20:31
  2. rev counter, speedo problem
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 21st August 2011, 21:41
  3. Speedo problem
    By amir2300 in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 21:47
  4. vectra c speedo problem
    By C-13UKO in forum Vectra C / Signum Troubleshooting
    Last Post: 27th March 2009, 10:52
