Thread: Dump Valve
    Jan 2010
    derby
    Default Dump Valve
    Hi has anyone puta dump valve to the 1.9cdti 150 engine in the signum. If so how easy was it, how much and where did you get it from
    Smartie1986
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    sure it can be done, but why a dump valve on a derv?
    from what i have read here all they do is make a racket and loose you power
    Worksop
    no dont do it i ave a bailey venturi on my 2.0t and it sounds lush
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Can of worms just u watch brmmmm tshhhhhhhh
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    There is no point putting a dump valve on a diesel because diesels aren't throttled like petrols. Dump valves ork on petrols because when you lift off of the throttle closes off and a builf up of pressure occurs in the intake line. Diesels don't do this, throttle plate is open most of them time even when lifting off the throttle pedal.
    West
    As above, complete waste of time on a derv unless you want the wooootshhh! noise only.
  1. 2.0 DTI dump valve ??
    By christianrickhuss in forum Diesel Engine related
    Last Post: 26th April 2013, 17:55
  2. Dump valve
    By irmscher-brett in forum Diesel Engine related
    Last Post: 24th December 2010, 14:45
  3. Replies: 23
    Last Post: 6th March 2009, 09:00
  4. Which Dump Valve
    By rob888 in forum Petrol Engine related
    Last Post: 23rd January 2008, 14:14
