Thread: Fault Code Advice.
    Mar 2011
    South Normanton, Debryshire
    Default Fault Code Advice.
    Hi,
    Just want some advice if anyone has had this with there car ive got the code P0100 Mass Airflow Voltage Supply. Coming up and not sure what to do next like i said has anyone esle had this and solved the problem if so how?
    My car a 2.0DTI if it helps.
    Mar 2011
    Bump
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Does car run ok?
    Are you able to see live data on your code reader?
    Can you measure voltage at maf?
    West
    Have you checked the wiring to the maf & or replaced it?
    Mar 2011
    Ive replaced the sensor then found a split in the pipe and replaced that.
    Checked the wires they seem ok but havent checked the voltage through them yet.
    On my friends scanner it did a few checks like showing you how much air it should be taking and how much it actually is and things like that (but this was when the car wasn't in limp mode) and he said they all seem fine but still goes into limp mode.
    Mainly it's when the car gets a temp to be honest but ive done trips down the motorway for like an hour and it wont come on.
  1. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  2. diesal fault code advice please
    By tj56 in forum Engine & Drivetrain
    Last Post: 10th February 2011, 11:33
  3. fault code
    By mats13 in forum Engine & Drivetrain
    Last Post: 22nd March 2010, 23:28
  4. fault code help pls
    By pipe rodder in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:19
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
