Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Who has an oil catch tank fitted?
    Engine : 1.9 CDTi
    Default Who has an oil catch tank fitted?
    Thinking about fitting an oil catch tank.
    Who has one fitted and how much oil do you end up with?
    Seen a few fitted on cars with the inlet/outlets point up slightly which looks odd but have seen this one: http://www.ebay.co.uk/itm/Nissan-180...item2a13a503f9
    Sprayed black and with the side inlets/outlets I think it would blend in quite well
    Regular Member hagga's Avatar
    kingswinford
    I've fitted one to my 3.2 http://www.vectra-c.com/forum/showthread.php?t=136988
    though on that particular tank i drilled out the fittings where they go into the tank as imo they were a lil small... get around 1/2 full every couple of weeks(approx 600-700 miles or so)... find it's more dirty water/lil mayo than oil(and no i haven't head gasket issues lol)
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    How many miles has your car done hagga? My cdti 150 has covered 80,000 and doesnt seem to collect much at all.
    Regular Member G4GAV's Avatar
    Bristol
    do oil catch tanks do anything? apart from catch oil....... my seem like a silly question but i always get told no such thing as a silly question.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    I fitted one just over a week ago, and it has caught nothing whatsoever, pipes are still spotless that lead to the catch tank.. odd...
    1.9CDTi 150
    Sep 2011
    MILTON KEYNES
    Thinking of fitting one soon, but does anyone know why you can't just pinch/block the hose that joins to the air intake pipe? Surely that would do the job of stopping oil mist getting into the inlet? Just a theory after looking at mine earlier....
    Engine : 1.9 CDTi
    Its a breather hose that needs to 'breath'
    If you block it you will cause a pressure build up could start to cause other engine problems like blown seals etc.
    West
    could cause crank case pressure to build up & something is likely to go pop
    kingswinford
    Quote Originally Posted by mally View Post
    Quote Originally Posted by john506 View Post
    1.9CDTi 150
    Ive done 100k in mine... question to both of you..what state were the pipes in you cut into? any mayo in there? if there was then you know there was oil/water vapour passing through them...if there was maybe catch tank mounted too high??(water comes from when oil cools and air is sucked back in and moisture condenses... many 3.2 owners see this as mayo on filler cap/top of oil spout)
    Quote Originally Posted by G4GAV View Post
    Not too sure on diesels but on a petrol the oil vapour can derate the octane rating..plus keeps the cr@p out of the throttle body that can also effect idleing.
    Quote Originally Posted by Dave Milton Keynes View Post
    Quote Originally Posted by lee gsi View Post
    Like Lee says.. I had my original breather freeze up in the winter and ended up blowing 2 rocker seals.. chucked oil out and ended up being towed home
    kingswinford
    And just to clarify things a little... This is the diesel section so I can't remark on how yours should be working as i've a petrol(i can go google it though)... I'd googled stuff and found most on evo's and scoobs etc before fitting to mine.. I mostly collect water in mine...with a little oil/mayo (no..this isn't some recipe for a light dipping sauce lol).. checking tonight I'd say get 1/4 to 1/2 full over 2 weeks (only had to top up oil between services about 4 times(from ownership..25-100k) and never had to top up water so I know it's not coming from the engine as such)
    edit: googled it for you oil burning peeps.. too lazy to type(or maybe a lil 'enginist' lol.. http://www.google.co.uk/search?q=oil...&aqi=&aql=&oq=
  1. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  2. Oil catch tank
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2011, 16:04
  3. Fitted a Oil Catch Tank for DTI
    By Innes in forum Diesel Engine related
    Last Post: 9th October 2011, 14:18
  4. Just Fitted Oil Catch Tank (couple of pics)
    By john506 in forum Diesel Engine related
    Last Post: 7th September 2011, 10:17
  5. Oil catch tank 2
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 30th May 2010, 20:52
