Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: MOT on Thursday
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Default MOT on Thursday
    Hey guys
    My Veccy has it's first MOT under my ownership on Thursday. Previous MOT was passed with no advisories.
    Work done this year includes rear shockers and upper arms, all four springs changed, new wipers, and back box welded.
    Car seems ok with no play in any wheels, etc, and barely any smoke when booted hard (2.2 DTi). Underside looks clean and solid.
    Car has done 16k miles since last MOT.
    Anything else you guys think I should check for?
    scottish region
    good luck hope all goes well mate
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by DAVIDD88 View Post
    Thanks mate
    Full Member
    Nov 2009
    Warrington
    good luck, my car is going in for its fist ever mot on thur morning. coming upto three yrs old now. taking it to nationwide autocare or halfords as they are now half price mot £27
    Regular Member wozza's Avatar
    Jul 2011
    teesside
    I always take my car to the local authority testing station where they do the taxis. Its only £35 and they do a fair test and aren't looking to fail you on things to pick up a bit of work. Last car went through 5 years on the trot no problems
    Regular Member sheepish's Avatar
    Yorkshire
    I always take mine to a place that ONLY does MOT's and nothing else. It's made a massive difference to my cars failure rates...
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Started the car this morning, and the exhaust knocked against the underside of the car as it fired up. Was only doing it on start-up though, not when driving.
    Sod's law when the MOT is getting done tomorrow
    Just replaced the rubber mounts on the back box, as they were, worn, to say the least. No knocking on start-up now
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Well I took the car for it's MOT this morning.
    On the way there, thought I'd give it a good thrashing to clear it out, for the emissions test. As I red-lined it, the car jolted violently and went into limp mode, and remained there. A quick look under the bonnet and I saw nothing obvious.
    Took it in for the test and mentioned that the spanner light was on. The lad says "that's no problem, just means you're due a service" Ok I said, no probs.
    Went to pick it up. It failed. No mention of the spanner light, but it failed as the outer CV boots are held on with cable ties, rather than the metal clips. Even though they are not leaking or split!
    Got home, on checking everything over in detail, the spanner light turned out to be a loose connection on the plug to the EGR. Sorted in seconds by pushing it back on
    So £20 lighter, I'm now faced with the task of changing the CV boots. Going to change the boots and clips, as they came as a kit from Euro Car Parts.
    Has anyone else had MOT problems for this?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    woudnt it just be easier to get some metal clip to secure the cv boots?
    I had this on a prevous car and 2 metal jubilee clips and it was sorted
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by justin32 View Post
    Just going to change the clips with the ones from the boot kit. On inpection, they're not leaking oil and not split or perished. Never thought of jubilee clips to be honest!!
  1. Meet this thursday
    By nidgeboy in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 24th March 2012, 16:40
  2. The Vectra Goes On Thursday
    By doughy in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 22:37
  3. Booked for Thursday :D
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2010, 13:14
  4. Vectra going Thursday
    By kevin hunter in forum General Chat
    Last Post: 8th February 2010, 13:06
  5. last thursday
    By mc_orion in forum The 'Off Topic' room
    Last Post: 18th October 2009, 11:49
