Results 1 to 10 of 11
Thread: no power at low revs
    Sep 2011
    glasgow
    confused no power at low revs
    How you doin, as this is my first 1.9 diesel, i dont really know if its ment to like this, at just over 1000rpm there seems to be no power until i get to about 16:confused, i was in 3rd coming off a roundabout and there was no power exiting it, do i need to have my revs up all the time or is this the start of an egr problem, does anyone have any ideas?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check if swirl bar still attached.
    Check all vac pipes for splits.
    Clean EGR valve.
    HTH
    I wouldn't expect any power at such low revs, would really need to be in a lower gear
    Sep 2011
    glasgow
    i keep comparing it to my leon fr that was remapped, it pulled from just over a grand, but ill still do the above and do the egr blanking mod, cheers
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Even on mine which has now seen over 240bhp on two rolling roads and can beat a remapped 530d on the road, below 1500rpm it's got nothing to offer.
    Sep 2011
    glasgow
    ill have to just keep the revs up, and get the remap and dpf delete done quicker than i planned
    Bristol
    If you have no power pulling away check your vac holes at the front of the engine check very carefully under elbow as they are prone to cracking . This will cause loss of power.
    Sep 2011
    glasgow
    thanks for that, ill check that aswell
    11 Post(s)
    Quote Originally Posted by tonyr101 View Post
    Commonly known as turbo lag.
    At low revs there will be no power. You need to get the revs up a bit higher to get the turbo spinning. ie, change down a gear.
    The following example is a petrol engine, but it should give you some idea about turbo lag. Start viewing from appros 50 secs in.
    http://youtu.be/VVt1IjIdLxY
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    I had a similar problem and in my car and I needed to change airflow meter. Now everything works fine.
  1. high revs no power
    By veccyDaz in forum Engine & Drivetrain
    Last Post: 29th May 2012, 18:31
  2. Low Power, Wont Go Above 3000 Revs
    By jammin31 in forum Engine & Drivetrain
    Last Post: 30th June 2011, 10:20
  3. no power at low revs cdti
    By brownlow39 in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 19:39
  4. Limited revs and power down
    By Ste in forum Engine & Drivetrain
    Last Post: 24th November 2009, 11:59
  5. No power between 3k-4k and high revs
    By troodon in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2009, 18:53
