Thread: Constant Velocity Joint problem?
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Constant Velocity Joint problem?
    Hi, I currently have a droning style noise whilst driving as well as clunking whenever i put my foot on or take it off the accelerator, I've tried turning on full lock left and right but cannot hear any clicking. There is sometimes a dull thud or twang which I thought might the spring. Any help greatly appreciated.
    Sep 2011
    Stockton on Tees
    Cant say much about the droning noise but the clunking coming off the accelerator could be a worn engine mount, or even worn bush on a bottom arm
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Quote Originally Posted by Gazza36 View Post
    that twang you mention, was the same as i had on my vectra, turned out to be snapped springs, i would check wheel bearings if you hear a drone when driving. As long as the boot around the cv joint is in tact, i wouldnt think it was the cv
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    As mentioned above mate check mounts.
    Also what tyres have you got?
    Jan 2010
    Cornwall
    Quote Originally Posted by CritchvxD View Post
    They're falkens ta.
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Aaa not cheap ones then was going to say droning could be cheap tyres.
    Jan 2010
    Cornwall
    Had the clutch and dmf changed and it seems much better but still slightly evident.
  2. Replies: 6
    Last Post: 9th June 2012, 10:38
  3. Rad fan on constant
    By Gavin2.6 in forum Engine & Drivetrain
    Last Post: 19th February 2012, 16:17
  4. Not constant revs around 3K
    By Boz657 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 15:55
  5. Replies: 12
    Last Post: 14th January 2007, 13:06
