Thread: help req for bleeding 3.0cdti vectra c
    scotland
    Default help req for bleeding 3.0cdti vectra c
    hi can anyone help? am looking for advice bleeding my 04 vectra 3.0cdti post fuel filter change?
    thankyou
    change filter , fill filter housing with diesel
    fit top to housing , tighten screw
    crank car over for 10 seconds
    repeat the cranking till vehicle starts but only in blocks of 10 secs at a time
    there is no need to bleed it as it bleeds itself
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by marktaylor View Post
    Unfortunately that is incorrect. Only the 1.9 has a self bleeding fuel system.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Mate only way I got mine going was taking screw out off filter an filling fuel filter through this hole until absolutely full.
    Then after a few cranks it will go.
    Failing that some carb cleaner straight into throttle body while cranking should start it
    Sep 2011
    Stockton on Tees
    Its a naughty way of doing it but tow start the car? this is how i got my golf mk4 to go
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Mine didn't go even after about 600 Metres of trying to tow start
    Oct 2007
    Telford
    I cracked off the union on injector 6 until it was flowing with clean diesel, tightened it up and bang off it went.
    Bristol
    The V6 cdti is self bleading if you change filter you only need special bleeding kit if you change fuel pump. Anything else is self bleading I have done it many times. If you remove filter put in new filter fill with diesel then just start car and let run for a few mins job done.
    Jun 2011
    Elland
    As above, you need to top the filter up... and fill it through the bolt hole.
    Tip: when you're filling the bolt hole (firstly make sure the area is clean), use one hand to maintain a downward pressure on the filter top (keeps a seal with the filter housing). Keep that pressure on, then with the other hand replace and tighten the bolt until the bolt takes up the slack and you can let go.
    If you've not attempted to start the car before filling the filter in this way, it should start straight up. If you have attempted to start it, it can take a few goes. If it still won't start, remove the filter outlet pipe and pour diesel down it until full. Replace the pipe. Refil the fuel filter through the bolt hole and you should be good to go.
    scotland
    Unhappy
    thanks for all the advice people
    i did fill the filter bowl up after i changed the filter and the car started ran for a while then it stalled so i opened the filter housing and it was empty tried filling it back up and it wont start am weary of damaging the pump
    but i will give these tips ago
    am sure its just being stubborn
    cheers much apprieciated
  1. bleeding bleeding and adjustment
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2011, 11:29
  2. Help bleeding the heating system on vectra c 1.8 ls
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2010, 00:34
  3. For Sale - Vectra 3.0CDTi SRI
    By spatch in forum Cars for sale
    Last Post: 9th October 2010, 11:45
  4. Buying a Vectra 3.0CDTi
    By LarfinBoy in forum Introduce yourself.
    Last Post: 5th April 2008, 07:38
vectra 3.0 bleed diesel system
